ssmiljanic
- Points
- 148
- Raider
- Talion
Hey there,
Just thought I would post a caution about these rear hexes. Switched out stock aluminum for STRC rear red hexes with STRC rear carriers. Lost 4 wheel nuts and stripped two tires. Took it all apart and switched back and forth btw stock and STRC hex, and STRC hex clearly binding on both sides. Tried washers on both sides of the hub and pre and post hex pin...still binding (even worse). Stock hexes though, smooth as butter even when the wheel nut is locked down. If just one side, then perhaps a manufacturing anomaly...but occurred on both sides even when strc hexes switched back and forth. If anyone has a better experience with these hexes please reply. The carriers are great, just the hexes are the issue. Stupid me trying to get everything in matching red...even a hex which no one sees when buried in the wheel!
