I only jump my trucks about 30ft into the air and I honestly think that most people don't even do that height . Sounds like you are having a good time with your rig.I picked one up, not to long ago, and have been really enjoying it! I don’t do 100’ jumps or 100mph speed runs, but I have a ton of fun with it!! I have a 50 acre field behind my house and they grow hay. Once it is cut and bailed I have about a week to rip it up!! I was running in my yard, but I was starting to leave tracks….wife said it was a “no go” area now.. lol
It’s a great piece of kit, but like other RC’s, break it down and check the fluid levels in the diffs and make sure all screws that screw into aluminum has blue locktite. I haven’t broken anything “yet!!”. Lol
Yes and yes!Any thoughts on the talion exb? Is it worth the money?
No, the Talion EXB comes with LSD diffs in the same configuration as the others - maximum effect in the front and middle and minimum effect in the rear.I did not know it was out... Does the Tailon EXB have all open diffs I did not see anything listed with LSD?
Why 4000-5000 cst oil in the shocks? I find the rebound is already incredibly slow with the standard 2000cst oil. Thought about going to 1000cst and see how it handles. Also checked the strength of the springs but they are very strong/stiff already. Yes the more upright shock position seems makes sense.
Thanks for that answer!
Yes, the low ride height on jumps is my problem too. That's also the reason why it's still stock - just less weight. My springs are pretty much totally compressed. Will change the shock position.
The slow rebound bothers me. Just too much distance is travelled before the shocks level out again. Making the front scape the ground unnecessarily. That's why I was thinking about 1000cst to make the rebound of the shocks faster. But that won't help with bottoming out.
