THE KING
Rhett
Starvin Delmarvin
Berlin, Maryland
Kraton, Outcast
The new Armma notorious absolutely blew my mind and met all of my expectations by far. I have a 14 pinion on my kraton and notorious has the stock 12 I assume and both on 6s . Notorious is faster and handles great
Rhett
Starvin Delmarvin
Berlin, Maryland
Kraton, Outcast
Throw that 14 on the outcast if there is more room on your face for a bigger smile!
Just did the 14 and motor gets warm not hot but warm. You think it'll be fine running around grass to? I do with my kraton and it does get warm not hot
Notorious J
THAT'S MR. POOP TO YOU BUDDY!
Canada
Notorious
I love how excited you are about your trucks. Makes me wish there wasn't a foot of snow and ice that needs to melt, before I can really get out again and start bashing. Keep posting these happy thoughts, it makes it feel just a bit warmer than it really is.
Notorious J
Canada
Notorious
What's the worst that can happen? Something blows and you replace it. It's all part of the fun;)
Rhett
Starvin Delmarvin
Berlin, Maryland
Kraton, Outcast
I just ordered a fan for the motor. That will keep her cool with the 14 speed gear
Notorious J
Canada
Notorious
The "speed" pinion in your new kit is a 16 tooth, and they don't recommend running it offroad at all. That 14 tooth is definitely going to heat things up a bit more, but it is still a new truck, so it's going to be more forgiving. The stock bearings are all metal shield, and are not as forgiving, so the more you run, the greater the resistance will rise. Like you mentioned earlier, that 12t is still giving you a great smiles/tooth ratio, and that's all running bone stock. Every change you make, should be followed by considerations about other parts that will be affected. If one bearing starts to go south, that resistance will inevitably affect the heat generated in the motor, as it tries to power through that resistance. I can go on and on, but I think you know what I mean. Even with the 12t, without some needed changes and routine maintenance, at some point your going to have to start wrenching. So choose your poison, blast it like its nobody's business, and keep the spares and tools at the ready.
PowerDubs
Military Veteran
I agree with no worries, break it, fix it- but I am also new to this truck.
So, 12 teeth is stock, 14 will be faster, 16 is what the speed gear is it came with....
I think I am OK with the 14 then.. what's the worst that can happen? ;)
At this point, I'm soo far in on everything- F it, lets have fun!
Same as when I was told to 'keep it to 4S' by everyone. Why? Yea I have to spend more on battery, charger, power supply, ....and I suppose wear and tear ...but if I am already 80% in... might as well not worry about breaking a $50-$100 part.
Anyone have the part # for the 14 if that is my best all around option for more speed on the Notorious while still doing grass, mild hill, jumps, ..
How many mph gain is it? How much does it decrease accel? I think I will be OK with a loss in decel given it just wheelies all the way across my yard while spinning tire all the way.. and I can up the punch which I haven't done yet.
Rhett
Starvin Delmarvin
Berlin, Maryland
Kraton, Outcast
It's insane bro 3/4 throttle and front wanting to wheelie and I have 500k in center diff 50 rear 80 front. It's scary because I don't have any room to much poop in the way lol
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast, Typhon
Not to mention the sub arctic temps.
Brewcity414 General Chaos 8
sentonist Arrma 4x4 Mega & BLX 20
GraniteRob007 Suspension 15
photobasher Kraton 13
Similar threads
