Hypnotoad
- Georgia
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
where'd you get the droop screws for your DB? Might have to pick up some of those for mine.Hello
It is a fun RC to bash....I really enjoy mine after few minor tweaks... I feel the shocks are good since it is not a jumper/send it RC and I run it like a desert buggy. The shocks respond REALLY good AFTER some needed changing.
- Stock Front Shocks: 30wt
- Stock Rear Shocks: 30wt
- 42.5/30wt f/r (currently running)
I like the 42.5 in the front along with the shock collars adjusted on all sides. Most important change was adding the drop screws. The shock pull at the shock bottom end. They did not add the droop screws in although it had a metal chassis. After adding those I adjusted the droops to take the stress off the shock bottom and this allowed the shocks to have the recoil they needed to be a good performer. Took that out you are seeing and they come back up when I push the front/back down quickly.... It would hang before the droops.
I posted that here:
https://www.arrmaforum.com/threads/...ead-by-alex-m-and-slick2500.14799/post-593673
See how the arms are more up after adding the droops this greatly helps the shock springs work as designed
https://www.arrmaforum.com/threads/...ead-by-alex-m-and-slick2500.14799/post-590228
