Someone is selling sct410.3 shocks for a really good price, I personally own a sct410.3 and tried to see if the shocks would fit on the DB but they are too long. Is it a bad idea to put shocks on that are to long so they are under constant compression to fit? Is there a way to properly mount up shocks that are a bit too long?
Thanks for the reply, I have been really struggling with suspension setup with these shocks. I recently took a gamble and drilled out my pistons to 1/16 and it did not go according to plan I lost nearly all damping until i mixed 60w shock oil with a few drops of 200k diff fluid lol. The front sct410.3 shocks fit perfectly in the rear but then I don't have a solution for the front.
What type of screws did you use to adjust the droop? I need to figure out how to bleed these shocks before I change the wt lol
Did a quick search and these came up...they look to have the right thickness but with no measurements not sure if they will work on the DBWhat type of screws did you use to adjust the droop? I need to figure out how to bleed these shocks before I change the wt lol
Hi parcou, I know that the DB is not meant for hard bashing but I actually find the car very durable after upgrading the driveline, the only thing i have broken aside from driveline was a shock rod end. My goal is to have these shocks absorb medium sized jumps. Do the droop screws only save rod ends and internals or is there a performance boost as well?
Couldn't you use these M5 screws and simply grind down the head end to make the head thinner?I went to Home Depot and found a few sizes and the M5x10mm were good with enough stem to part through. I did have to machine or dremel a flat notch in the end of the screw but that was easy to do so I can turn it with a flat head. The M5 head could be a little smaller (M4) but it works I need the treads to me M5 width so to find that with a smaller head would take more time. No issues just a big head I wanted more droop...it would be an issue if you wanted just a tiny bit of droop since the screw head is so big. So think on that before getting these and if you find something better...post it back here:
I posted about what I found and used at Home Depot. I posted a LOSI part number I ordered it just to see if it is a direct fit will let you know when I get it... the link is above...ok cool, sounds like a cheap part that can help a lot. Does anyone know any that fit and have the part number?
@Hazardyok cool, sounds like a cheap part that can help a lot. Does anyone know any that fit and have the part number?
Sir, I spent weeks reading all pages here on diff oil and what people are using....it is ALL over the place on diff weights that makes my numbers and stock weight look wrong. I just bash it and I do not care to jump this one is not made for sending....here are my notes:I just got a DB Pro in the mail and the center diff leaked all over the box. 2 questions:
- What diff oil weights are most of you using?
- Is there a video showing taking out the center diff? The diagram in the back of the manual isn't hugely helpful for me.
Thank you so much for the info. My LHS doesn't have those weights so I just ordered some and it'll be here this weekend.Sir, I spent weeks reading all pages here on diff oil and what people are using....it is ALL over the place on diff weights that makes my numbers and stock weight look wrong. I just bash it and I do not care to jump this one is not made for sending....here are my notes:
Again ppl are using weights I have seen for the Infraction and Big Rock...each his own
- current - 7/10/5 f/c/r - June 12, 2021 trying 7/15/5
- OEM
- Front Diff: 5K
- Center Diff: 5K
- Rear Diff: 3K
See if I can find a video.... center is easy removing the screws under the bottom of the center diff and on the top one all few it will allow you to pull it out and remove the center driveshafts have the center diff in hand..
This guy is long-winded but the beginning of the video shows him removing the center diff/motor
