- Nero
Typhon arms didn’t change from v4-V5. So they should be backwards compatible with your v4 chassis. Or if you ended up stretching your V5 you could update the typhcast and not have to trim the arms
apologies to the original poster for the derailment!
the outcast 6s is a kick in the pants. The best all around stunt truck in my opinion. Tough as nails and the best part is it could probably literally wheelie for miles if for the terrain and the range. It’s not tippy as you described it’s quite planted for being a short wheel base... arrma did a good job there. If your looking at one don’t hesitate!
