- Granite Grom
- Infraction
- Kraton EXB
- Senton 3s
I might get a vendetta if I can run my 6s system in it would I need an adapter for my motor shaft and if so where can I get one
This^^^If you were to go with a 2050kv 6s motor, for instance, they have 5mm armature shafts. You would have to find a .08 mod pinion gear that has a 5mm I.D to fit.
6s seems overkill for a Vendetta. Perhaps running 4s is more appropriate. Depending what your objective is. Are you looking for 150+Mph speed runs with that Vendetta? You will be tearing up that drive train in heartbeat. Forget the fact that it will be a bear to even hookup. Just get a Lim/Infr instead. If you don't have one already. Get away from the 4x4 line at this point. A Lim roller is only $400. FWIW. Better suited for 6s running, IMHO. Less issues.
If just bashing and drifting it, 6s might be the wrong approach.
Just me.
+1Get a 6s and scrap the ebrake thing and maybe swap the plastic center diff for metal. If the 4x4 was $320 or less like it used to be it might be worth it but not anymore…
This is mine with 6S motor and escI might get a vendetta if I can run my 6s system in it would I need an adapter for my motor shaft and if so where can I get one
