Looking at a TP 4070 for a Limitless build that I will be pairing with a MAX5. Did a little bit of research but thought I’d ask about opinions for the available options:
1) 5mm vs 8mm shaft - any reason to go for one vs another?
2) Vented vs sealed end caps? I assume vented is fine for a Limitless being run on asphalt
3) 2080 vs 2250 - any preferred KV for 6s?
Thanks!
Thanks!
