Hi guys
I wanted to change the stock pinion on my typhon v5 to the optional speed pinion they provide in the box… I’ve never done it before. This might sound stupid but is it the cog that’s attached to the motor? If so what is the best way to get it off? I can’t see the shaft so I can’t remove the grub screw.
I know il need to unplug the 3 motor cables and undo the top 2 screws (so it can slide) but I do I need to remove the full motor from the car to be able to change the pinion?
Any tips advice or home videos provided would be greatly appreciated
Thanks for your time
