FriedOne
- Infraction
- Kraton 8S
Picked up my Talion 3 weeks ago. I performed the following upgrades so far.
Set punch to level 6
Replaced rear wing mount with RPM Wing Mount #RPM81642
Installed RPM Rear Skid plate #RPM81442
Upgraded Rear A-Arms - RPM81722
Installed RMP Rear Mud Guards #RPM81532
Upgraded Front Right Upper and Lower A-Arms #RPM81602
Upgraded Front Left Upper and Lower A-Arms #RPM81572
Upgraded front steering blocks with HR Aluminum Steering Blocks HD Bearings #AON21MA01
Upgraded brass steering bushings with Sealed Rubber Bearings: Size 6x10x3mm Traxxas #TRA5105
Replaced ESC fan with a 35mm Rocket Aluminum Fan @ 20 000 RPM
Installed 2x 30mm Aluminum Rocket Fans @ 28 000 RPM
Replaced Rear Diff fluid with 30K
Replaced Centre Diff fluid with 500K
Replaced Front Diff fluid with 60K
Picked up some 60Wt Shock Oil : Oil change to be completed.
I'm still running stock gearing. Any suggestions of what to tweak next. This truck is running so well now, lots of acceleration and she runs pretty straight. Steering is smooth and very responsive.
Thank you to all you Guys who have helped and answered my questions. It's because of you guys that this hobby is so awesome.
Cheers ALL.
Cheers ALL.
