Thanks for the advice. Pretty clean build!!Yep, loads more torque and cooler temps as well. With the low height of the body the larger can motor makes it a little rough to fit a heat sink/fan very well. I like the hobbystar 4092 1730kv motor in both of mine.
Do you think it’s able to be done? 1650 in the talion and the body fit.Yep, loads more torque and cooler temps as well. With the low height of the body the larger can motor makes it a little rough to fit a heat sink/fan very well. I like the hobbystar 4092 1730kv motor in both of mine.
Yeah it'll fit fine. May run cool too depending on your gearing. I was able to kinda angle a 40mm fan in to fit sideways under my body. That one may need a little more creativity.Thanks for the advice. Pretty clean build!!
yep I have to open it. Was trying to make sure before I broke the seal and couldn’t return it without restocking fee’s. Thanks everyone!
True, but getting a heat sink to fit the 4985 is a little tougher. I think people have got the yeah racing one to fit with some modifications. The 8s xmaxx heat sink works greatl. I 40mm fan all of my rigs, i run a pretty high gearing though.The 10mm thick fans shouldnt have any issues with fitment though
So, how are the temps on the motor? No esc overheating?I put it in (max 6 with the 1650kv) and I can’t believe I was questioning doing so. Everything fit fine. With the talion’s servo mount it was a tight squeeze. I didn’t know where I wanted to be as far as gearing goes but I figured the optional 23t arrma pinion that came with the exb was a good place to start. It didn’t have enough ass for my liking so I went down to a 20t. loving it lol
