- Points
- 1,793
- NC
- Infraction
- Limitless
- Kraton 6s
- Notorious
- Outcast 6s
- Talion
- Typhon 6s
All these spare parts builds popping up recently got me motivated to build a couple new Arrmas of my own.
Build 1: 8s Kraton/Talion Hybrid
Got most of the parts already minus the a v4 Kraton body and tires. (Still deciding on what film to hydrodip the v4 body in).
Tires will more than likely be the new Backflip LPs wrapped with 50lb braided spiderwire to keep from ballooning while bashing at high speeds.
This will be a Kraton with an M2C Talion chassis for better front to rear weight distribution, and powered by a Max6 ESC and 4985 1650kv motor running (2) PowerHobby 4s 5200mah 50c packs for 8s
Gearing is 20/46 for a target speed of 80mph
*** Edit 9/15/19***
Final Build Specs v1.0
~ M2C Talion v3 7075-T6 Chassis
~ HR Front & Rear Chassis Braces
~ Voltage Hobbies Front & Rear Shock Tower
~ M2C Rear Skid plate
~ RPM Front Bumper & Arrma Typhon Pin Retainer
~ HobbyWing Max6 3-8s ESC
~ Hobbywing 4985SL 1650kv Motor
~ Tekno 20t Pinion
~ Arrma Infraction 46t Spur
~ Twin 30mm HobbieStar Alum Fans
~ ProModeler 470 HV (440oz-in/0.12 @7.4v) Servo
~ Voltage Hobbies Servo Mount
~ Arrma V4 Motor Mount
~ Front Diff 60,000cst
~ Center Diff 1,000,000cst
~ Rear Diff 30,000cst
~ Outcast Wheelie Bar & Wing
~ dBoots Backflip LP Tires Wrapped with 65lb Line & Sealed
~ Custom Hydrodipped Kraton V4 Body
*** Edit 9/15/19***
~ Tekno 20t Pinion
