- Statesville nc
- BigRock 4x4
- Kraton 6s
- Kraton 4s
- Outcast 6s
- Talion
- Typhon 3s
Can't wait for the vids?
Shutdown space is completely overrated and unnecessary imo. As you know.....Ed and I have been working diligently behind the scenes on secondary methods for drastically reducing acceleration through the use of stationary objects like trees and shrubbery, thus far..... with mixed results71 mph in that small space @Mr.Duke! Your target speed of 82-83 seems totally viable but just how much space would you need? And when I talk about space, I'm referring to braking room as well. I got the Noto maxed out recently (pretty sure it was anyways) and bringing it to a halt took me by surprise. Lucky there was the tire of a parked car to stop it from hitting a concrete curb. My guess is I was in the high 40's low 50's but the distance to stop was what i hadn't accounted for. Can't wait to see the top end on yours once you find the right place to do it.???
As you may have seen in some of my videos, I too have used similar principles for decreasing the speed of decent on some of my jumps. The result thus far has been very good, as the speed is reduced to zero almost immediately ?Shutdown space is completely overrated and unnecessary imo. As you know.....Ed and I have been working diligently behind the scenes on secondary methods for drastically reducing acceleration through the use of stationary objects like trees and shrubbery, thus far..... with mixed results
We will keep you posted on further developments from our testing
Interesting! I may have to start launching at full speed from now on, no matter how small the space. If what you're saying is correct, something or someone will stop it. ?Shutdown space is completely overrated and unnecessary imo. As you know.....Ed and I have been working diligently behind the scenes on secondary methods for drastically reducing acceleration through the use of stationary objects like trees and shrubbery, thus far..... with mixed results
Absolutely bad ass brother!I spent tonight finishing up version 1.0 of my 8s Kraton build by putting the final touches on like thread lock on screws, body pins, wheelie bar, GPS, alignment and so forth.
Found a home for the Garmin GPS under the wing and plan on taking it out for a street bash sometime tomorrow to see how this 4985 performs on 8s. I'm actually more concerned about the tires holding up than I am about the motor. Running 20t pinion and 46t spur has me geared for 82-83mph
I'm pretty pleased with how it's turned out so far. Now I just have to keep from blowing it up ?
I can already tell that running 1M center diff fluid is going to be really hard on the rear input cup. After one pack it's already wearing a small divot and putting a heat signature on the pin at the contact point.
That's the only thing I found on a thorough post run inspection
