SOLD / FOUND $350 OBO ARRMA TALION 6S EXB ROLLER M2C HOT RACING RPM DURATRAX AVID BEARINGS.
Status
Not open for further replies.
Avyn Nix
  1. Kraton EXB
This is my Arrma Talion 6S exb roller with many upgrades.
Upgrades Include:
M2C Chassis
M2C 6-lug hex adapter kit
M2C Steering Bar
M2C Rear Chassis Brace
Hot Racing Center Diff Holder
Hot Racing Front Chassis Brace
Hot Racing Servo Mount
Hot Racing Rear Hubs W/ HD Bearings
Hot Racing RR Hinge Pin Holder
Hot Racing T-T Brace Mounts
EXB Shock Towers
EXB Kraton Bumper
EXB Front Toe Links
EXB Front Arms
RPM Rear Arms and RPM Rear Skid Plate
Arrma DBoots Backflip 4S Tires
Also includes Duratrax x-cons truggy tire/wheels w/ 1/2in offset, M2C drill guide to drill new wheels, arrma front wheel bearings, spare wing mount parts, and 25T Spektrum servo horn.
Almost all Avid Racing bearing I think the only ones that aren’t are the front inner wheel bearings.
Need to complete:
Esc
Motor
Servo
RX/TX
Battery
Charger
Thanks for looking.
Images are below.
Upgrades Include:
M2C Chassis
M2C Steering Bar
EXB Shock Towers
EXB Kraton Bumper
EXB Front Toe Links
EXB Front Arms
Need to complete:
Esc
Motor
Servo
RX/TX
Battery
Charger
Thanks for looking.
Images are below.
View attachment 267449View attachment 267450View attachment 267451View attachment 267452View attachment 267453View attachment 267454View attachment 267455View attachment 267456View attachment 267457View attachment 267458View attachment 267459View attachment 267460View attachment 267461View attachment 267462View attachment 267463
You need a price to post here
My price is in the title is that okay, and how do I edit it if it’s not.
Ok awesome 👏
What do you all think of it?
The dirt on the rear arms and all tires was impossible for me to get off I don’t know why, any tips? But almost everything else is nearly spotless and I stripped the whole thing down to clean it as well.
Ok I was using brake cleaner could that be the issue?
That could potentially eat the plastics… and will definitely eat at your bearings and o-rings.
Here are some of the things I use..
Simple green
Oil eater
Soap and water
Alcohol wipes on some stuff..
Once it’s mostly clean, I then spray with wd-40 and blow it off with an air compressor so I know that all the water has dissipated ..
Wd-40 = water dissipation.
If spraying with water or saturating with cleaners…. removing your electronics is recommended.
Hope this helps.
Awesome Thais I’ve never had issues with the brake cleaner damage the plastic but I will try out your ideas.
Ok I’ll try it out thank you guys for all the help.
What simple green do I get I see there’s a lot is there any difference besides price.
The foam works great! Spray it on, wait a minute or two, then blow it off with an air compressor. Makes things look new again. I usually have to buy it off Amazon, but you may get lucky in your area.
I bought the regular spray before I knew about the foam and it worked great. I just sprayed it on, rinsed it off while avoiding electronics and use air compressor/datavac to blow dry it.
Status
