FireDrake001
- Typhon Mega
XT90 is officially rated to handle 90 continuous amps, while the Max5 G2 is rated for 250 continuous amps.All I can do is give you hands on personal experience. Not sure what other people have tried. But for me I have never needed QS8's. I have a lot of 12s systems, 8 to be exact, none use qs8's. Aside from the x-maxx and infraction the other 12s systems have been ran upwards of 50 to 75 times.
I run the Max 5 G2 250amp 800kv 56118SD in two of my rigs. I use XT90's with no issues, they don't "rephrase" get to hot. Pretty sure as long as your not doing 200mph your fine. The X-maxx has at least 15 to 20 full packs though it. I run 8s/10s/12 configurations on Both the infraction and xmaxx. The X-maxx has had 12s ran through it 3 times full to lvc.
90amp rated yes "continuous." Peak 180 each, most times running 2 of them.
Shouldn't this work the other way too?I can't in good conscience tell someone it's wrong when it works just fine for me.
Unfortunately, no it doesn't. It isnt past its spec's in a dual config. Technically in if you think of it like that a single xt90 on a max8 is super bad news, but its 100% not.Shouldn't this work the other way too?
We should not, in good conscience, convince someone to use a connector beyond its maximum capability, as defined by manufacturer specifications.
Can you explain what you mean by "dual config" and why that matters here?Unfortunately, no it doesn't. It isnt past its spec's in a dual config.
2 lipo's 2 xt90's, its not pulling but half from each.Can you explain what you mean by "dual config" and why that matters here?
Hmm. That doesn't sound right to me. Wouldn't each connector in series wiring experience the maximum current? You can't use 50a connectors in a 100a system just because the two connectors are wired in series.
I mean Team Associated uses Deans on the MT8, that doesn't mean it's the right choice. Luckily in their case the car will break before you can manage to melt the connector
I laugh when I hear of those T-Plugs. (Deans Ultra plug copies) that all the Cheap OE's still use. TA RTR cheap crap etc.I mean Team Associated uses Deans on the MT8, that doesn't mean it's the right choice. Luckily in their case the car will break before you can manage to melt the connector
Honestly I was kinda thinking the max 5 v3 200 amps withAt best you will risk damaging the ESC from ripple current and possibly blow the caps, at worst the connectors will melt together and the ESC could die. What are you considering the Max 5 for? I don't mean to belittle your project, but saving on batteries with QS8 is very low on the priority list when building out a rig that specs something like the Max 5. The Max 5 is a ridiculously powerful system that generally goes in 1/5 scale cars that cost 1000+ dollars. A QS8 connector is like 20 bucks to put on a battery or two, and those packs need to be really strong lipos, generally high capacity, high discharge, from a reputable vendor like CNHL, SMC, or Onyx if you're going to run a Max 5.
my project is upgrading and building up a Losi Dbxle 2.0. I use xt90 on everything so having now qs8 would make compatibility problems. I plan to get most of the aluminum upgrades and run the max 5 with the 56110(somewhere around there) stock spektrum motor on a 18 tooth pinion. Wouldn’t the max 5 v3 and the max 6 g2 work? 200 amps and both run 8s?At best you will risk damaging the ESC from ripple current and possibly blow the caps, at worst the connectors will melt together and the ESC could die. What are you considering the Max 5 for? I don't mean to belittle your project, but saving on batteries with QS8 is very low on the priority list when building out a rig that specs something like the Max 5. The Max 5 is a ridiculously powerful system that generally goes in 1/5 scale cars that cost 1000+ dollars. A QS8 connector is like 20 bucks to put on a battery or two, and those packs need to be really strong lipos, generally high capacity, high discharge, from a reputable vendor like CNHL, SMC, or Onyx if you're going to run a Max 5.
I mean i know someone that i bash with that has that exact vehicle and esc/motor. They use xt90s and have for a long time without them overheating.Honestly I was kinda thinking the max 5 v3 200 amps with
