gabcauseican
- Thread starter
- #21
Lmao.....let's go to school okayMaybe because your question is unclear?
What is 6s2x5200?
Why do you think 12S is potentially going to be faster than a 6S setup? Or even an 8S setup?
See MATH wasn't your SUBJECT huh?
Remember I said people talk from EXPERIENCE not THEORY....ATLEAST the ones I MET.....THEORIES can be debunked I see you talking from LACK of
6s 5200 100c is my battery ZEE LIPO
6s =voltage
5200=ah(amp hour) NOT amps
100c= discharge ratings
5.2x100=520 AMPS what the ESC use
2 6s5200 100c PARALLEL =6s10400mah 200c
4 6s5200 100c = 2 6s10400 200c
2 6s10400 200c series = 1 12s10400 200c
10.4x200= 2080 AMPS
2080x2 = 4160 AMPS
2080x4 = 8320 AMPS (if I'm lucky)
400amp ESC
400x2 =800 Max amps(most ESC should do double they power no problem)
400x4 = 1600 AMPS If I'm lucky
You joking right? You must be TROLLING. why
22.2v 6s x400 amps =8880
44.4v 12s x 400amps=17760
How is it not? What ever SETUP you running double the power(3s go to 6s) tell me if your car go faster or not..... YOU said you a SPEEDRUNNER ? Nah you #TEAMMACKSAUCE (YOU don't GOT IT)
Realize I can go up to 16s(67v) with my ESC
That's the difference you FOLLOW people and just gear up..... me I OVERVOLT
Who win battery or esc?
what's your ESC AMPS VS your batteries AMPS
You can have the biggest and baddest motor but it's limited by THE ESC and BATTERIES specs.....
****after I start to calculate what motor ****
say it with me gabcauseican don't listen to NAME brands.....he like the NUMBERS
*Hint ROLLER option(no ELECTRONICS)
I jondilly1974 like the NAME brands........ they do the NUMBERS for me cause I don't like too/know how
Wait how are you calculating your SPEEDRUNS
You just BUY NAME brands and hoping?(You listen to what others say, you taking other people SETUPS and claiming to be FAST?)
Now go have a seat with yourLV(low voltage)3s(12v) 4s(16v) LMAO SPEEDRUNNER you SAY
Class session done...........
I built my car....... you bought yours........lmao
****Lesson of the day......don't be like jondilly1974....... do your HOMEWORK
Please answer the question now
