Maagneticc
- Infraction
- Limitless
- Kraton 6s
- Typhon 6s
What Do You Guys Use To Lift A Kraton Up Abit The Shocks don't Go back up that high after I push down on it
Are your shock shafts bent? It should not go all the way up on its own when just sitting on a surface tho. You want a bit of droop naturally.What Do You Guys Use To Lift A Kraton Up Abit The Shocks don't Go back up that high after I push down on it
That’s Normal Height when pushed downAre your shock shafts bent? It should not go all the way up on its own when just sitting on a surface tho. You want a bit of droop naturally.
Can we see the shock collars?That’s Normal Height when pushed down
If I lift it up the spring just moves aroundCan we see the shock collars?
Now I'm confused to your original question? Those are fully extended and the a-arm is fully down. I wouldn't run with full preload like that though. Your asking for busted shock rod ends.If I lift it up the spring just moves around
This is how I got the car 2 days ago idk anything about arrmaNow I'm confused to your original question? Those are fully extended and the a-arm is fully down. I wouldn't run with full preload like that though. Your asking for busted shock rod ends.
V1 or v2 fo sho. Those springs really suck.They look like V1 or V2 shocks with the soft springs and 3.5mm shafts
I’d upgrade all the shocks to v3 or v4 or at least put the stiffer springs on it from the newer version
