- Thread starter
- #21
You caught me, my bulk order of plastic parts set you off?Traxxas spy
That's just tolerating crap behaviour from Arrma.Sorry bumped the reply button.
Sadly if I made a list of all the things I would check on a rtr before I drove it, you might as well just completely rebuild the car. That is why people refer to rtrs as ready to rebuild. It's just one of the downfalls of mass production. It's definitely something that you should check after a run.
I completely disagree with your statement. When you buy a car or bicycle from a store, they are responsible to give them a complete once over to make sure the factory assembly was complete and nothing was left off or loose. Even a computer may need a firmware/software update after you take it out of the box. Unfortunately, with "toys", the standard of assembly is not nearly as high as other consumer products, so if you plan at running an rc vehicle at the scale equivalent of 480 mph out of the box without checking it first, then you deserve to be disappointed. The only crap being tolerated here, is your idiotic ranting.That's just tolerating crap behaviour from Arrma.
You don't expect to have to rebuild a car, or mountain bike, or laptop, or anything else when you buy it, why should an RC be any different?
If you don't go over a full scale car that goes as fast as these do scale then you're not too bright. I don't trust people that much.That's just tolerating crap behaviour from Arrma.
Ok, go climb into a OL Street drag without looking it over. Then you can tell us how it's someone else's fault that you hit the wall.The arrma apologist here are nuts. It's not fine to expect something to be incorrectly assembled. It shows a lack of quality control and a lack of respect for your customers.
If you're building toys that are this fast and this capable, then fiddlesticking build them properly. There's no justification not to, and it's moronic to make excuses for them.
Apologists? You brought up three comparisons that were quickly shut down. A single loose nut on a mountain bike could kill you if you were running a downhill course. You wouldn't give the bike a once over after taking it home from the store to make sure the employee that was having a bad day, didn't forget to tighten all the nuts so the handle bars or wheels won't fall off? We're talking about one loose screw on a toy car, and it's the first time this part has ever been mentioned on this or any other forum. The only thing Arrma has been accused of repeatedly, is putting to much thread lock on most of the connections, making them hard to take apart. You jumped in pretty quick because one person found one loose nut, and lumped Arrma into the despicable category. Good luck with the next car or bicycle you purchase, and be sure to tell them to forgo the pre delivery inspection, because you know that the factory got it right and you trust them.The arrma apologist here are nuts. It's not fine to expect something to be incorrectly assembled. It shows a lack of quality control and a lack of respect for your customers.
If a screw is supposed to be threadlocked and isn’t, that’s incompetent or lazy assembly.I don't see a screw backing out as being something that was assembled incorrectly. Arrma also provided one of the best warranties on the industry. If something fails, they replace it. Seems like they are taking responsibility to me. These trucks are built by humans and mistakes happen. At least Arrma stands behind their product.
That screw isn't supposed to be thread locked! It's mounted into a lock nut, and it's possible that the chinese factory that produces them, made one with a bad rubber seal. Maybe all the Arrma employees should have microscopes to check every nut and bolt before assembly.If a screw is supposed to be threadlocked and isn’t, that’s incompetent or lazy assembly.
As for replacing things that fail, does that mean we should expect to see them offer free suspension arms for the Kraton 4s, since it’s becoming apparent that a lot of units are failing due to bad molding.
Yes, apologists. I’ve only been here a few days, and already whenever Arrma fiddlesticks up, there’s a chorus of “oh it’s not Arrma’s fault, you shouldn’t expect to have these things assembled correctly, or to have faults”
You’re all fiddlesticking crazy, acting like the concept of a working product is an impossibility, an unicorn, not something to be expected.
Quit drinking he frigging cool-aid, these things are pretty flawed, Arrma is not your saviour
There it is again. Who said they should warranty crappy driving? Bad injection molding - something that falls under the banner of quality control - that’s what they should be honouring.Personally I think it's nuts that they should warranty someone's crappy driving.
Who says it's bad injection molding? You? You are the authority ? Can you tell me how much force one should expect an A-arm to take? Is it infinite?There it is again. Who said they should warranty crappy driving? Bad injection molding - something that falls under the banner of quality control - that’s what they should be honouring.
The fiddlestick is wrong with you all?
Yes she isYes, apologists. I’ve only been here a few days, and already whenever Arrma fiddlesticks up, there’s a chorus of “oh it’s not Arrma’s fault, you shouldn’t expect to have these things assembled correctly, or to have faults”
Actually the steering step screw happened to me awhile backApologists? You brought up three comparisons that were quickly shut down. A single loose nut on a mountain bike could kill you if you were running a downhill course. You wouldn't give the bike a once over after taking it home from the store to make sure the employee that was having a bad day, didn't forget to tighten all the nuts so the handle bars or wheels won't fall off? We're talking about one loose screw on a toy car, and it's the first time this part has ever been mentioned on this or any other forum. The only thing Arrma has been accused of repeatedly, is putting to much thread lock on most of the connections, making them hard to take apart. You jumped in pretty quick because one person found one loose nut, and lumped Arrma into the despicable category. Good luck with the next car or bicycle you purchase, and be sure to tell them to forgo the pre delivery inspection, because you know that the factory got it right and you trust them.
Here he goes again.There it is again. Who said they should warranty crappy driving? Bad injection molding - something that falls under the banner of quality control - that’s what they should be honouring.
Quoting this again.Sorry bumped the reply button.
Are you still under warranty? Shits broken.Quoting this again.
This repeated mantra of RtR meaning ready to rebuild, it's just not fiddlesticking good enough.
Give it a fiddlesticking rest, and demand better.
