- Tel Aviv, Israel
- Granite
- Senton 3s
- Talion
- Typhon 6s
- Typhon 3s
- Voltage
Correct, but body will not sit as low, giving it that cool low slung look.
It looks like the body posts are different too?Could always get a 2nd Granite, slap some ST wheels on it and a different body, and gear it up. You’d still have more travel/ride height but otherwise they’re basically the same truck based on the posted specs.
High speed basher I'm assuming?
This is the fastest and most technically advanced 1/10 scale 4x4 vehicle in the ARRMA lineup.
Arrma Vorteks Features
- Stadium truck body with tough, injection molded wing and protective roof skids
- Adjustable body mounts
- High-traction, vented dBoots® Katar™ multi-terrain tires mounted to tough, gun-metal color wheels
- Spektrum™ 3660 3200Kv brushless motor with ARRMA® heatsink and cooling fan and Safe D pinion
- Spektrum™ Firma™ 100A Smart ESC
- Spektrum™ 2.4GHz DX3 transmitter and SR6200A receiver Smart radio system with AVC® (Active Vehicle Control®)
- Spektrum™ SPMS651 metal-geared servo
- Strong composite chassis with extended height dirt defenders
- Easy-access modular design
- Adjustable turnbuckles
- Steering system with stone clearance
- Adjustable ride height
- Wheelie bar
- Rubber shielded bearings throughout
- Durable 37T 1.35 module metal differential gears and silicone O-rings
- Castellated slipper pad and sliding gear mesh
- Plastic locknut for slipper
- Double wishbone suspension front and rear
- Oil-filled shocks with silicone O-rings
It is 55mph on stock pinionHigh speed basher I'm assuming?
Tires,shock towers,esc radio with smart ready and other stuff that we already know.Especially since the only net new thing is really the radio.
So what is its compitition?
I kinda like the body. The boxy bodies are wearing on me. It's something Arrma can add to their tool box to rope in new customers. Might see some leave the VXL and come over .After seeing the videos of the vorteks 4x4 theres a lot of changes specially the shock towers. And its faster than any 3s in the market i believe atm out of the box at 55mph on 17t at 20t it will hit over 60mph. It got me worried that arrma was fellowing traxxas adverisement with that huge claim in the box. The traxxas rustler claims 60mph but does 42mph out of the box the option pinion gives u 52ish mph and its cooking the elctronics you had to buy a seperate pinion to hit that 60mph. Happy to see this isnt the case with the vortek. But the colors suck man only the purple looks nice. The v2 arrma bodies were perfect why change it to more ugly ones
Rustler is 479$ right? The vortek is 380$
It's just a Vaterra V100 with worse electronics.The Losi release looks interesting - maybe some competition for the 4-Tec.
I saw that too but it crosses paths with the granite. Maybe if it was 6 S. I don’t have a reason when I have a new GraniteA few people have already mentioned it, but it seems alot of people missed the main change in the Vorteks. Yes, it has upgraded electronics, but the main change is the lower shock towers and shocks. It's kindof Arrma's fault so many missed this major change, because Arrma doesn't mention it ANYWHERE.
These parts are all completely new and exclusive to the Vorteks. 4x4 BLX owners who enjoy high speed/ripping turns and mainly stay on the ground should be very interested in these as upgrades to their Granite/Big Rock/Typhon/Senton (I'm assuming they are compatible, I could be wrong)
https://www.arrma-rc.com/part/ARA320634
https://www.arrma-rc.com/part/ARA330722
https://www.arrma-rc.com/part/ARA330723
https://www.arrma-rc.com/part/ARA550091 Judging from YouTube reviews, the tires are a bit firmer which should minimize ballooning at high speed
Not sure how this guy got a Vorteks 3 weeks ago. But you can see the difference in handling. The short wheel base and short shocks make the Vorteks a really quick stable turner and it stays on the ground at high speed. The rest of the 3s line does not run like this.
Is this because it lays the shock flatter vs the rest of the 3s lineup so the suspension movement is more progressive, so it loads and unloads less under small compressions and ramps quickly under large ones? Better on the ground handling at the expense of less ability to absorb hits from huge jumps etc?A few people have already mentioned it, but it seems alot of people missed the main change in the Vorteks. Yes, it has upgraded electronics, but the main change is the lower shock towers and shocks. It's kindof Arrma's fault so many missed this major change, because Arrma doesn't mention it ANYWHERE.
