- The Netherlands, Europe
- BigRock 4x4
- Kraton 6s
- Kraton EXB
- Typhon 6s
- Thread starter
- #41
Just installed the Team Durango diff cups and it's a direct fit. The cvd's have no binding!
From Germany, modelbaubochum.de (i live in the Netherlands). It does seem the only shop in the world who can still supply TD parts...Hi
Where did you get the out drives from.
I thought the Senton and Typhon have the same geometry, i'll check the manuals. Something must be different, thanks for the tip!So I installed the front cvds onto the rear of my senton and been through 8 packs and no binding or blown bearing, super happy.
Just need to stop bending rear shock towers :/
Yes, they fit on all 6s Arrma'sWill the Durango diff cups work for all of the arrma’s?
I think that's it. And I want to say yes.Thanks for the info in this thread! I ordered the TD310480 from eBay for $10 with shipping and a set of driveshafts from JRC for $25. Is there anything else I will need for a Typhon 6S V4? Are the bearings the same size in the stock hubs front and rear?
Yes the bearings are the same size. Only the HotRacing alu rear hubs have lager bearings.Thanks for the info in this thread! I ordered the TD310480 from eBay for $10 with shipping and a set of driveshafts from JRC for $25. Is there anything else I will need for a Typhon 6S V4? Are the bearings the same size in the stock hubs front and rear?
Right so I’ve made a boob then!
I’ve ordered a set of Typhon front CVD’s off Jenny but I now need to source some TD310480 diff cups for them to fit!
I’m more of an IPA guy myself ??Yes the bearings are the same size. Only the HotRacing alu rear hubs have lager bearings.
I haven't cracked a bearing with this combo the past year!
I forgot were youre located bro.. I know a german LHS who has em..
Modellbaucenter by any chance? ?
Modellbau bochum.. Indeed..
But.. Im not sure why you would need em.. I built my (V3) left front CVD into my left rear just yet.. And seems to work fine with the stock outdrive.. Shocks all the way in.. Tire comes up just as far without problems..
