- Location
- Germany
- Felony
- Fireteam
- Infraction
- Kraton EXB
- Outcast 4s
- Vorteks
Castle just released their new XLX-2 ?
First video from Raz:
And an 1100kv 2028! This must have been what innovation RC was talking about in his teaser.Castle just released their new XLX-2 ?
Looks promising but never going to reach its potential on speed runs without tyres.......
500A opens up the possibility of a whole new range of motors to blow up tyres
That is entirely thanks to you guys on this forum. You guys gave me feedback on the Monster X 8S, saying you wish is had mounting screws and I took the feedback to our mechanical engineers and got them to add the mounting holes to the bottom of the case.And it even comes with mounting wholes ???
I see you have found the same frustrations with the speed run side of the hobby that I have!
Remember these are theoretical/Imaginary amps. If the current worlds highest output battery is around 350 amps (SMC Extreme V2 6400mAh) how do they get 500amps?
https://www.arrmaforum.com/threads/battery-load-test-comparison-from-rcgroups.26877/
Example of the SMC V2 tested as a real 60C (advertising says 150c) (test revealed 5689 mAh versus 6400 on the label)
60c * 5.689 Ah = 341 amps
The amps are not imaginary. We have very accurate current sensing resistors in the PCB along with a high speed 14 bit ADC. I'm not going to say with the max reading is, but I highly doubt anyone will ever be able hit it. We have tested and verified that it is correct well in excess of 500 amps. Also it has a much higher resolution in the datalogs than any other product we have ever made. You should see logs with a resolution steps of 0.1 amps.Remember these are theoretical/Imaginary amps. If the current worlds highest output battery is around 350 amps (SMC Extreme V2 6400mAh) how do they get 500amps?
Some YouTube mega stars have already posted data logs showing 500+ ampsThey don't get 500 Amps; It's capable of handling 500 Amps....
It is highly possible that the data visible from the testing for LiPos is limited due to their testing equipment?The amps are not imaginary. We have very accurate current sensing resistors in the PCB along with a high speed 14 bit ADC. I'm not going to say with the max reading is, but I highly doubt anyone will ever be able hit it. We have tested and verified that it is correct well in excess of 500 amps. Also it has a much higher resolution in the datalogs than any other product we have ever made. You should see logs with a resolution steps of 0.1 amps.
ESC Only: $249.95 https://www.castlecreations.com/en/mamba-xlx/mamba-xlx2-8s-33-6v-esc-20a-peak-bec-010-0167-00
ESC with 800kv 2028: $469.95 https://www.castlecreations.com/en/...sc-with-2028-800kv-sensored-motor-010-0167-01
ESC with 1100kv 20280: $469.95 https://www.castlecreations.com/en/...c-with-2028-1100kv-sensored-motor-010-0167-02
The comparison datalogs on this page really show how powerful this ESC is:
https://www.castlecreations.com/en/xlxvsxlx2
We are extremely excited by this ESC and can't wait for more people to try to push it to it's limits. Good luck ever getting the 50mm fan to turn on.
A lot of those lipo tests are conducted over fairly long periods of time. They see how many Amps a lipo can output over ~a minute. Peak output is much higher than their ratings often times. We have dozens of logs over 450 amps from our beta testers. They also went through a lot of lipos and cars. I've lost count of how man people destroyed their car. You'll see a lot of Lipos rated with two C ratings, often like 60C/120C. The 60C is what they can do for an extended run, and the 120C is what they can do for short bursts. Their test equipement can read higher, but they would ruin the battery packs trying to pull that much current from them continuously.Some YouTube mega stars have already posted data logs showing 500+ amps
LiPo Test Link
Our (the consumers) understanding is that consumer LiPos do not exceed 360 amps output. Not trying to throw stones @robert@castle we highly appreciate you coming on this forum, and sharing your knowledge.
I would love to hear more about what LiPos can truly output, if you are saying they can output 500+ amps, and these other tests we have seen are incorrect.
