- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
So last July I bought arrma metal input gear ,ring gear an cup 50-60$.for just rear cause that's all I was blowing out...thought is was better than the HR at the time...more weight an more power an then I started blowing front diffs under braking....so I took a chance on a cheap aluminum diff from ebay that hobbyking had...installed it an ran it with no issues..some test hits today I heard the dreadful skipping,stripping of gears under power.disassembled car an compared diffs closely for 1st time..the arrma diff has much more runtime on it,but the teeth surface area an much longer input shaft an a bunch of 130,140,an few 150 hits an I'm sold on the 31$ diffs...arrma diffs stripped 2 spools teeth cause the short teeth..input gear on arrma diff about done
