Hello! I'm building a fireteam with 2 motors and I don't know where to mount the batteries (4x 3s 5000mah). Does anyone have a Mojave/Fireteam with 2 motors? share your photos
Is top mounted batteries layout good?
How they do that? (It doesn't fit between motor mount and rear axleThat’s the longest chassis in the 6s line. Take out the factory battery boxes and take a long look at your layout. Change it if necessary. There are guys that have done dual motor SWB (328mm) builds. You are blessed with a whole lot more real estate to work with. You can do it.![]()
Yup, like @Tex Koder said, get rid of the handbrake assembly. Thats a good start. Then eliminate the T2T bar and replace it with a flat carbon brace. Then you can mount electronics on that and free up room on the chassis. What’s the rig going to be for? On road speed running on an XLWB chassis? If so you can also add GT side skirts and get a lot more room.
