- UK..
- Infraction
- Mojave EXB
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 6s
So, I finally got some free time to test the Outcast 8s didn't have a 25T as suggested but had a 26T..
Bit disappointed to be honest....
My setup currently is Max5, TpPower 5660 1054kv, 26T/47T
I used the usual SkyRC gps to measure the speed and it only managed 44mph, that was on a flat paved road so it's now slower that stock..!!
Trying to understand where to go next, change spur or pinion or both..!!
How do you judge the max RPM of a motor if you have no telemetry to look at ??
Would I be right in saying if you under gear you could exceed the max RPM ??
Motor temp..!!
I know D wind's run hotter but this is a bit much I think vs the ESC and batteries temps ??
( this was after only around 5-7 minutes of bashing around, full speed pass or two and some jumps.!! )
ESC temp..
Battery temp..
Curious what sort of top speeds you's guy's are getting in your Outcasts and the temps ??
Any tips or help greatly appreciated
Motor temp..!!
ESC temp..
Battery temp..
