RC BOY
It was my first day driving my senton 6s blx and the fan kept on getting filled with pebbles and grass and getting jammed how should I fix this.
Panty hose.Thank you very much I will do that.
There is a reason that the fans on pretty much everything blow the air down onto the heatsink instead of sucking it up off the heatsink, the only time a fan will work better sucking air off a heatsink is if there is another fan blowing air into it. It is just the ways all fans work on every electronic device.I do flip the fan over, makes more sense to pull air over esc and blow the heat up, also keeps debris from plugging fan.
