maxgasmekl
Hi - on my Kraton exb with the HW Max6 1650kv kombo, the teeth on the pinion keep getting worn very fast. They are stripped after 6-10 runs. Im aware that its a powerfull setup, but Im easy on the throttle and drives a 20t. The mesh is correct. A little on the loose side to try to keep the centerdiff cooler. The centerdiff gear is not very worn. Whats up?
And in addition, it looks almost like the one side of the pinion teeth are pressed flat. I don't know if it makes any sense. Its like the spur hits the pinion like a hammer. But it should be able to withstand that? I guess?Hi - on my Kraton exb with the HW Max6 1650kv kombo, the teeth on the pinion keep getting worn very fast. They are stripped after 6-10 runs. Im aware that its a powerfull setup, but Im easy on the throttle and drives a 20t. The mesh is correct. A little on the loose side to try to keep the centerdiff cooler. The centerdiff gear is not very worn. Whats up?
