TalionSWB
- Points
- 108
- Talion
Hi
Im looking to upgrade the stock BLX 4074 2050kv motor to a Leopard 4092 but not sure whether I should get the 1730kv or the 2080kv Leopard 4092 motor to run 6s Lipo.
I know you can gear up the 1730kv but why bother gearing up if you will get the same amount of torque as the lower kv leopard motor at higher kv?
I know heat is a reason for the lower kv but the stock 2050kv motor runs just fine on 6s so why wouldnt the 4092 2080kv motor run just as well on 6s?
