Hector_Fisher
Considering all else is the same between the runs that @dure16 did, i think a better metaphor is: voltage is like water pressure in a pipe, and amps is the amount of flow in a pipe. Wire gauge would be equivalent to pipe diameter. Amps are the indication of how much load you are applying to your system -- a measured or observed value based on the characteristics of your truck's build.I think the math is straight up but I think the concept is lost. These are Si Units and you can see the ugly math on Wikipedia if you like, but this is the one liner.
Voltage is the amount of potential something has. Like a bucket pouring water in to a pipe. The higher the bucket the more potential it has.
Current is like the size of the pipe. If you have a giant pipe it will drain the potential quickly.
Power is just multiplying the two. Says how much power can you have from your bucket and pipe.
High potential with skinny pipe is the same as low potential with fat pipe. How much water can you get down there at one time?
So
5V*1A is 5W
5V*.5A is 2.5W
10V*.05A is 5W
So you can have higher voltage and lower current, which is generally more efficient.
You can take power and dice it up and compare it to other things like MPH or RPM to optimize what you want
It's a bizarre thing, I know.
I think what we need now is more data to fill out the sample size and better define what's going on. A sample size of 1 is not nearly reliable enough to draw deep conclusions. My MT410 is set up to be able to run the 3s to 6s packs that I have, but I can't quite reach full throttle without it flipping backwards and taking flight. Maybe i'll slap on some hoons/GRPs and see what I can come up with, or swap in the mmx into my SCT410 and try to get some data.
