Misc. designs I've uploaded to Thingiverse
suchtragedy
(┛ಠ_ಠ)┛彡ɯɹɐ loɹʇuoɔ ǝʞoɹq
Wenatchee, WA
4x4-Mega, Granite, Infraction, Limitless, Outcast 4s, Typhon 3s, Voltage
Hey guys,
I just wanted to link some of the recent designs I've uploaded to Thingiverse that some of you may find useful. Enjoy at your leisure. I'll update the original post on this thread in the future with new designs as I publish them.
Arrma 3s/4s TPU Wing Mount:
https://www.thingiverse.com/thing:4503718
Remixed version of original design that @jondilly first made, published with his permission
35mm to 30mm/40mm ESC fan adapter:
https://www.thingiverse.com/thing:4503682
Allows you to replace stock 35mm ESC fans and replace with a more common high speed/cfm 30mm or 40mm fan installed on top of Hobbywing/BLX185/Spektrum/Hexfly 6-8s ESCs. Design does NOT require you to remove the ESC plastic cover to install
Arrma Infraction/Limitless ESC Mounting Plate:
https://www.thingiverse.com/thing:4495981
Screws into the 4 holes in the stock ESC mounting location so you can attach the plate with double sided tape your ESC of choice but making it also removable without having to rip the tape apart and replacing it again each time you remove the ESC
Hobbymate Speed H6/HOTA H6 Pro Charger Stand:
https://www.thingiverse.com/thing:4484740
Puts the charger on it's side at a 30% upward angle so you can see the screen from across the room
Arrma Kraton 8s Heatsink Dual 30mm Motor Fan Adapter:
https://www.thingiverse.com/thing:4460604
Allows you to install 2x30mm fans on the Arrma Kraton 8s Heatsink replacing the stock 50mm fan
Hobbywing Push-Button Style Power Button Mount for the Arrma Infraction/Limitless:
https://www.thingiverse.com/thing:4460584
Designed to screw on top of the Infraction/Limitless receiver box, makes it removable and no more sticky tape. Works with most Hobbywing 1/8 to 1/5 scale ESCs with the push button style power button and the various rebranded versions as well
SkyRC GSM-015 GPS Mount for Arrma Infraction:
https://www.thingiverse.com/thing:4460557
Installs on either the front/rear body mount bar. Recommended install on the rear because the GPS will sit snuggly under the truck bed when the body is mounted preventing it from popping out in case of crash (unless you lose the body, that is)
There are other designs uploaded that you all might find useful but I've shared them before so I didn't want to relink them. Just look under my Thingiverse profile for the other designs if you're curious.
Yas
UK
Notorious, Outcast 6s, Typhon 3s
These are awesome... were these designed in a sort of CAD programme? I don't know a lot about 3D printing but I could see myself getting into it eventually
suchtragedy
Wenatchee, WA
Just Tinkercad, www.tinkercad.com. it's a free online based 3D modeler that uses preset shapes to use as a base of designs that you manipulate/transform and go from there. It's a bit cumbersome to use at first but you can figure things out quickly. Lots of vids on youtube.
Jerry-rigged
Have you seen my LVC?
Texas, Baby!
4x4-Mega, Kraton 6s, Outcast 6s, Typhon 6s
nice collection!
I have been working on a SKY-RC GSM-015 case, "finished" it Friday. Not on Thingiverse yet, but I think I can share the Tinkercad link. Have not printed it yet, my TPU is giving my fits. I think I need to dry it.
This is just a case with some zip-tie holes to mount it.
https://www.tinkercad.com/things/6sse99n33fv
Create account
Log in
