Hey forum ?
My Senton 3s is producing some unsettling sounds and i'm having trouble finding out what the issue is. Before it started, i had opened up the motor (everything looked fine), changed to a 15t pinion, changed the diff syrup (100k/30k), put on 17mm hex adapters and buggy tires and tried adjusting the slipper clutch.
Now the Senton makes a very loud grating sound under acceleration, much louder than the usual noise. It does not happen when im holding the car up and all wheels are spinning freely. When i'm holding the rear tires in place and pull the throttle, the front tires spin and i can hear the grating. When i'm holding the front tires, the rear tires spin but there is no (or very little) grating.
I have taken another look at the pinion and spur gear - the teeth are fine and the mesh looks alright. The differentials and input gears looked fine when i changed the syrup.
I tried loosening and fastening the slipper clutch, but it did not seem to make a difference.
Any help is appreciated!
