snowleopard888kk
- Limitless
That motor won't run on 8s.
Model: LBP4082-B/1.5Y
Max Amps: 140A
Lipo Cell: 5-6s
Max Power: 3500W
KV(RPM/Volt): 2200
Resistance: 0.006
No-load Current (7.4v): 3.9A
Diameter×Length (mm): Φ39.8×82
Mounting hole depth: 7mm
Length of extend Shaft : 20mm
Shaft Diameter (mm): Φ5.0
Weight: 485g
Warning: Operating the motor outside of the specifications listed above can either damage the motor, battery or esc. It is important that these components are set up properly. Failure to do so can void the warranty. It is strongly encouraged to use a Watt Meter to test the watt and amp performance when setting up a new system. If the output is above the factory recommended specs, then it needs to be adjusted by the esc. The timing and throttle settings on the esc can help to set the appropriate levels.
what about this leopard brushless motor 5892
