2wd brushed 1/10 it needs a body and batteries i just got it some guy traded me for a whole bunch of 18650 batteries i gave him1/10? 2wd or 4wd? Brushed or brushless?
really digging the boats this summer. I have the river jet boat, ran hot until I installed the Hobbywing seaking pro 120am esc, can't recommend that upgrade enough !
The thermal cut out has erm cut in thanks for the inforeally digging the boats this summer. I have the river jet boat, ran hot until I installed the Hobbywing seaking pro 120am esc, can't recommend that upgrade enough !
https://www.ebay.com/itm/Hobbywing-...283391&hash=item286e825d65:g:PXYAAOSwN3Na1sAc
fairly new to boats but what do you think about this one? https://hobbyking.com/en_us/turnigy-rc-boat-esc-120a.htmlreally digging the boats this summer. I have the river jet boat, ran hot until I installed the Hobbywing seaking pro 120am esc, can't recommend that upgrade enough !
it's a 120 amp, with more water cooling than the hobbywing. give it a try.fairly new to boats but what do you think about this one? https://hobbyking.com/en_us/turnigy-rc-boat-esc-120a.html
i shall when i get a minuteit's a 120 amp, with more water cooling than the hobbywing. give it a try.
Ugh... why does traxxas still put the stupid body mount posts so close to the edge of the body on the stampede. It's infuriating! That's the first place the body rips apart is between there and the fender regardless how much tape/reinforcement I put there.My Old RCs finding these from when I was younger is what helped me buy a Arrma. I still may restore the RC10T it needs some love still have the rims and tires.
Best advice I can give you is to pick up some adjustable turnbuckles iirc the ones from a Team Associated T4 are the proper size, some Rpm heavy duty 440 rod ends, some spare Ecx ball studs, get rid of the stock servo saver, I used the rpm servo saver eliminator(if you get this you will want a metal geared servo the stock one won't last) Ecx and Hot Racing both make upgraded units, get the metal gear set if you plan to go brushless, replace the front axle carriers with aluminum, the stock ones will just rip screws out and Rpms do the same.2wd brushed 1/10 it needs a body and batteries i just got it some guy traded me for a whole bunch of 18650 batteries i gave him
Nice Rock Rey, I just ordered the Bind and Drive Baja Rey. These are supposed to be pretty durable. Once you swap out the stock servo and servo arm/servo saver.My Losi Rock Rey...
Also have
-Proboat Recoil 26
-Traxxas MERV
-Several drones
-HPI Savage
Thanks! I'm still on the fence about getting the Baja Rey, my buddy has one and it's awesome! These trucks crush the axial variants. Mine is "slightly" modified but one of my favorites now.Nice Rock Rey, I just ordered the Bind and Drive Baja Rey. These are supposed to be pretty durable. Once you swap out the stock servo and servo arm/servo saver.
Since yours has the orange beadlock wheels I'm assuming you have the Bind and drive version. I got an SSD front diff case, Fast Eddie bearings, and a Vanquish Currie rear axle on the way.Thanks! I'm still on the fence about getting the Baja Rey, my buddy has one and it's awesome! These trucks crush the axial variants. Mine is "slightly" modified but one of my favorites now.
Those are all great upgrades! The biggest difference that I found is changing the shocks out to the proline powerstrokes. Ride is greatly improved with those.Since yours has the orange beadlock wheels I'm assuming you have the Bind and drive version. I got an SSD front diff case, Fast Eddie bearings, and a Vanquish Currie rear axle on the way.
Nice, I'm planning on running those as well.. I actually already have the 6063-00 powerstrokes for the front from the Slash 4wd, I still need to order the rear.Those are all great upgrades! The biggest difference that I found is changing the shocks out to the proline powerstrokes. Ride is greatly improved with those.
Those shocks make these vehicles butter smooth compared to stock. Sorry everyone for so much info on none Arrma vehicles ?Nice, I'm planning on running those as well.. I actually already have the 6063-00 powerstrokes for the front from the Slash 4wd, I still need to order the rear.
