ArrmaGeddonBash
I'm new to R/C and I am about to order the Kraton EXB but before I do I need your help with a few questions so I know what to buy
Battery Questions: How much run time (i know it varies) on average can you get with a Spektrum 5000mAh 4S 14.8V 100C Smart LiPo?
Do you get more run time with two 2s 5000mah batteries?
ESC Question: I am getting this ESC https://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMXSEMC05 ... If I choose to run one 4s battery. How do I dummy plug the other connector. Idk what that means? I'm assuming it means you put a plug in it and leave it be or something else?
ESC/Motor Question: What is a safe Temp under operation for the ESC/Motor?
Kraton EXB Questions: When the EXB was newly release it had diff issues. Are those issues fixed now or should I buy some diff fluid/tekno shims for the rear?
Are there any parts that are prone to breaking? What spare parts should I order to be on the safe side?
Thanks in advance!!
Thanks in advance!!
