Kraton Spektrum RC S9120BL 1/5 Brushless High Torque Metal Gear Servo (High Voltage)
gotnitro
1st place
Just saw this on Amain. $225. In stock mid MAY.
https://www.amainhobbies.com/spektr...-gear-servo-high-voltage-spmss9120bl/p1217594
Specifications:
Application:
1/5 scale off-road
Bushing Or Bearing: Bearing
Connector Wire Gauge: 18 AWG
Connector Wire Length: 6 in (152mm)
Deadband: Micro sec: <1
Gear Material: Steel
Height: 1.84 in (27.2mm)
Length: 2.47 in (62.7mm)
Motor Type: Brushless
Servo Operating Voltage: 6.0 - 8.4V (HV)
Servo Size Category: Custom
Speed: 0.29 sec/60 deg @ 6.0V, 0.23 sec/60 deg @ 7.4V, 0.21 sec/60 deg @ 8.4V
Spline Count: 15 Teeth (15T Mega)
Torque: 1173oz-in (84.47 kg-cm) @ 6.0V, 1209 oz-in (87.06 kg-cm) @ 7.4V, 1453.5 oz-in (104.66 kg-cm) @ 8.4V
Type: Surface
Weight: 6.3 oz (178.6g)
Width: 1.18 in (30mm)
Damn very nice.
I have no problem with my stock servo but 1400 oz is something to brag about.
I scooped one a couple weeks ago. (y) Wish I knew about that one before dropping a buck 50 on the 9020!
Me too. Can you confirm how many ounces of toque it is? When I tried to convert 70kg to ounces I got a ridiculous response.
How do you do that conversation?
if on windows you can try https://joshmadison.com/convert-for-windows/
but usually its KG * 13.88 = oz/in so 73 * 13.88 = 1013.24 - someone correct me if I am wrong but there are ~ 35.2734 ounces in a KG and 2.54 centi-meter in an inch, the correct conversion factor is 35.2734 / 2.54 = 13.88
Torque: 62kg / 6.0 volt / 860.56 oz
73kg / 7.4 volt / 1013.24 oz
so a bit less powerful than the Spektrum at less than 1/4 of the price
That would be spot on if it were 73KG but it's 70.
Raminator Monster Truck PM1373 70KG High Voltage Digital Steering or Brake Servo
Noob question here, but can I just reset my BEC voltage to 8.4V with stock electronics and get more torque out of the servo? I can’t find the ratings of the stock unit but don’t mind if I shorten it’s life. Will I cook the fans?
Eventually yes. Some guys did this before they upgraded to a better servo.
