Gilgamesh
Granted it was my fault, had the punch set to 9
Nah I'm sure I had everything on right and tight.That sucks! Are you sure you the hex was aligned properly as well in the rim, might have been another possibility? Or possibly the wheel nut came little loose and the hex and rim misaligned causing the hex to strip out the rim. Punch set to 9 shouldn't cause this alone has to be some other factor as well.
