SeaOfChaos
- Typhon 3s
Replacement fan. 35mm Rocket.
View attachment 298488I ran my Kraton V5 hard against my brother and his Sledge. My fan started glitching on and off and then my yellow wire melted the soldier on the 4mm connectors. My punch is at 7, timing @ 15°, 15t mod 1 pinion. The male and female connectors were blackened inside and out. I replaced with Castle 4mm female and good electric soldier. Has this happened to you? Was.it over use?
Replacement fan. 35mm Rocket.View attachment 298489
+!Remove that heatsink and install a proper fan setup, thank me later!!
Same here, only the heat wrap was holding it together. Angles where totally gross.yea i had the same thing happen to me but mine completely melted
Probably around 135°f , but the wire must have been really heating up. I usually feel the back of can or shot my temp gun. Now I check the wires first!What were your motor temps when that happened?
