- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
Stretched typhon will be on upto 115-120ish..then you need better center shafts...pinnnocio spool setup or you'll start have the longer shaft bending an tearing $hit upOk, I'll make that change. Took frank out for the 1st time w/ it stretched & lowered this morning. We have a pretty good/smooth 2 lane highway in front of our shop. There is a bridge @ one end that I've already crashed into a while back & it has those mini rumble strips in the middle but the surface is pretty good other than the occasional piece of gravel. I think I need to dial in the ride height some more because it was scraping on every little pebble. We are right next to a reservoir tho & sometimes picking up satellite reception is iffy- as was the case this morning Ran it back & forth about a dozen times- had a blast!! Tracking straight w/o a gyro. Wot for about 5 seconds, I would guess 70 something? Looked fast- faster than I'd gone before that's for sure! Anyways, thanks to all of you experienced speed demons out there for helping a slow poke out!!
