I have a bud that is starting to mod his felony, but is quickly running into traction issues with the factory Hoons. Who makes some good foams for the felony ? Thanks
You don't say .. you could also do hub extenders but idk how well it would hold upSwapping the diffs would allow it to run infraction wheel options. So he’d have the same size tires all around and the felony body would look off being the rear tires are tucked in
Also, if you’re having traction problems with Hoons you sure don’t want to go to foams, which have the least grip of anything.I have a bud that is starting to mod his felony, but is quickly running into traction issues with the factory Hoons. Who makes some good foams for the felony ? Thanks
