Carbon Fiber
I've not had the chance to try it myself..
But I've heard this to be recommended plenty >>
$45 @ amazon
https://www.amazon.com/Polymaker-PA...Cardboard/dp/B09MTBF55V/ref=asc_df_B09MTBF55V
Polymaker has yet to fail me. Reasonably priced and readily available.
Layers with a 0.6mm nozzle are beautiful and never an issue with adhesion (using a PEI textured build sheet freshly washed in hot water and Dawn dish soap).
Which one do you use? It looks like they have several flavors.
Thanks. He gave a great overview. I wonder how PC CF stacks up.
Sure thing 👍
Guess the only way to find out is to get a roll and make some of your own prints. 😉
not had any luck with carbon fibre for bashing. but not had any of the good stuff from basherqueen
how often should I be cleaning my plate?
Anything carbon is more rigid, but also more brittle.. it's a double edge sword... as mentioned the layers look great for sure..
I'd venture away from pla, use a petg, PA or PC carbon blend.. obviously If the parts are trinkets then pla would be fine..
As far as branding, these day's I don't see much difference between cheapo and brand name, besides carbon content %..
You'll probably want to get another PEI build plate so you can always have one Ready to Go while you clean up the other.
Every time. I wipe with 99% IPA before each print and with soap/water after a print with glue.
Sure thing 👍
CF filaments are expensive!
Stress Testing the Polymaker filament
