SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
- Thread starter
- #61
@slick2500, no Film on the body like you would see on a Clear paintable body, if that is what you mean.
Out the box it had a loose plastic layed over for packaging protection, FWIW?
FT Update.
- Rebuilt all 3 diffs. All 3 diffs were low on oil as usual. Factory used one shim ( main gear side) on each F and R diff. I easily fit 2 shims each. Using the included bagged spare shims
I used 60K Fr/300k C/30k Rr.
>>>>One disturbing issue I noticed was with the Center diff:<<<
The oil was dark like it was USED already! See the pix below.
The stock satellite gear shims were scored and worn. How could this be?
The F and R diff oils were clear like new, as unused diffs would appear. Not the center one!
It was never run before! At least by me.
Reading the manual it clearly states that you never operate the Handbrake when throttling ( For or Rev) This will ruin the center diff causing undue wear/shock loads to it.
I can clearly see why Arrma installed the Metal diff at the center. I am sure including the Metal diff was an afterthought Necessity part after testing it and before production. Arrma never includes the Option Part Metal diff with their RTR's because they are so nice and gracious, IMHO. HB does a number on the center diff.
That HB is not any great revelation. HB is not even needed for off road use. Simple Throttling and Steering can yield the same results IMO. Per the many Reviews. Some reviews never even mention the HB. Other said it was removed completely. At the very least, I will try it. Then unplug the HB servo till I get a proper C block. HB mount is integral with a HB specific C-block.
Has anyone noticed how badly the plastic HB mount twists and distorts when operated? And there is no provision for setting the 3rd Channels's Endpoints with the SLT3. What a crappy HB!!!! Also I can hear a buzzing whine when the Brake is not engaged while you have it throttled. Sounds like my Nitro rigs Brake. The braked disc spins fast between the Brake shoes, causing a high pitched buzzing frequency. All FT's uniquely sound like this.
-I noticed my Rear Bulk head was stripped at the bottom ( 2 M4 chassis FH screws), unfortunately nothing new here .
-It is wise to use longer M3 FH screws backed with nuts at the leading and trailing edges/ends of both L and R chassis side guards.
One Review stated that the short screws pull out in these areas. Makes sense. What I did.
- The Firma 2050 motor is garbage. It screams violently sitting unmeshed to the Spur. Horrible. Sounds like it's an old well used motor ready to die. I will Warranty that absolutley. I am getting a HH warranty list together.
I suggest to anyone to check theirs. While the motor is unmeshed. BLX motors should always Hum very quietly. At least when new.
Despite lubing it and checking it over, no change. Motor is junk. Again it's New and never ran before.
It sounds horrible. I am tempted to show a video in regards. It is that bad.
-My FT droop screws have 2 washers on each and were bottomed out. I felt the need to adjust my droop. Or the Shocks End's will absolutely snap off. Basically I made all 4 droop screws threaded ends "even"/level with the top of the arms. My better judgement says Droop needs to adjusted, despite how they come from the factory. Should be set up like any Kraton rig.
- I didn't want to do it, but I will top off the shocks. Maybe even rebuild all 4 for what its worth. Staying with stock Oil and pistons.
They are all low on oil. I can hear the air squishing within all 4 of them at only half Compression stroke.
I can see that the the FT has been a mixed bag, assembly wise, for many. Just what I come to expect these days with Arrma.
I won't cry much about it. I only paid $400.
Getting a long list together for HH.
Nothing new here.
Below is the Center metal diff with OIL that looked like it was used. The satellite gear shims, were worn and well scored. Clearly not a new unused diff here.
Below is the center diff with 300k oil bleeding out air inside my Tamiya Shock pump.
FT Update.
Nothing new here.
