Senton Having issues with my blx180
Troymarchione
Winter springs fl
I been noticing it’s been getting worse throttle response every time I play with my senton 6s and tonight during a race it lose steering so I put a new servo and went to turn it back on and not it won’t send power to my receiver anyone else had this issue and fix it
I been talking with arrma about replacing it but I can’t find my receipt so any help will be appreciated thank y’all for your time in advance
Hi, and welcome,
Do you have the STX2 transmitter? If yes, then the problem can come from the trasnmitter/receiver. Lot of issues with this STX2.
Hi, and welcome,
Yes I also tried my dx4 and a sky fly
Crazy part is if I hook up a battery pack to my receiver it works
So, it should come form the BEC from the ESC. Are the three wires in good condition? Plug? Can you measure the voltage and current which come from the BEC while the car run, with the wheels out of the ground? With a mulitmeter you would see if the current/voltage are constent.
You have a BLX180? Not a BLX185? Just get on a kit breaker site and order a BLX185 ASAP. That 180 is a ticking time bomb.
I’ll check that later today I charged my battery and plugged it in now I have throttle but no steering again
