lluna2012
Hey all,
New to the Forum, and new to RC as well. The Kraton is my first RC, and has been my only thus far. Running on a smart 6s 5000mAh 100c battery. I jumped the car about a week ago and once it landed it lacked in power and had this terrible grinding noise. I know these Kraton’s are loud, but this does not sound right to me. I cracked all three differentials open thinking I would find either chipped or broken gears. All differential gears look fine. I pulled the motor away from the gear and the motor runs fine, and sounds fine. I replaced the pinion gear just in case, but the noise still exists. I have replaced bearings and have shimmed the center differential with used shims, just to see if it would slightly help until the ones I ordered get here. The noise is still just as loud as it was. Any help would be greatly appreciated. Local hobby shop has looked into the car and could not diagnose the problem. My next step if I cannot get a solution from you guys is to send the car for warranty. Thank you for your help in advance!
Also, the link for the video is below! Thanks for looking!
