You own a Fiat!You are so correct on feeling like a kid. Don't worry I am sure this will work perfectly on my future Kraton 8s build
ANDARE BAMBINO ANDARE!
Looks like another can with a straw in itProbably is but I think there is a fix or two for it. We shall see, it is a monster, that is for sure.
Hmmm how about big girl pantiesAbsolutely qualify as well!
.Let's see that GIF ( BIG GIRL PANTIES)
@djrahbee has the vitavon steering setup and still had to dremel/grind some material down to fit the 56113mm motor.Okay, need some advice on steering upgrades. I am looking at the M2C and the Vitavon specifically. Does anybody know which of these will give me the most additional space? The 56118 motor is even longer than the 56113 (by just over 5mm) I can get the motor in behind the Upper suspension arms with the wheels hard left. The moving part of the steering assembly hits the motor when trying to straighten out the wheels. Hoping one of the upgraded units gives a little more clearance.
Thanks in advance,
huauqui
PS I will try to add some photos in the am.
Sounds like you might have to flip the motor around and reconfigure the layout? Mine barely fits!@djrahbee has the vitavon steering setup and still had to dremel/grind some material down to fit the 56113mm motor.
I feel sick now thx
Oh yeah, my little Carlo Abarth special is a blast. But she is also an addiction much like RC. Much of her is no longer stock, suspension, intake, exhaust, programing, etc... Love it! Andale, Rappidisimo.You own a Fiat!
Will do! thanksLet me know if you need bigger battery trays
Just curious..have you looked into flipping the motor around and stacking the batteries on one side? I haven't seen it done and wondering if it's an option.Oh yeah, my little Carlo Abarth special is a blast. But she is also an addiction much like RC. Much of her is no longer stock, suspension, intake, exhaust, programing, etc... Love it! Andale, Rappidisimo.
Will do! thanks
Thanks for the info. I have not yet looked at flipping the motor but will definitely look into it. Been a crazy week at work and no real chance to play with the Outcast.Just curious..have you looked into flipping the motor around and stacking the batteries on one side? I haven't seen it done and wondering if it's an option.
Here is where I had to dremel..
Whatever you do, don’t put a full heatsink on that motor. It would just block airflow to the built-in cooling fins.I am researching mounts and fans for the motor,
Great advice, thanks. Also, thanks for the links, I will check those out.Whatever you do, don’t put a full heatsink on that motor. It would just block airflow to the built-in cooling fins.
Didn’t think that motor fit ?Probably is but I think there is a fix or two for it. We shall see, it is a monster, that is for sure.
