Is it in there??? Take a guess....🤣🤣🤣
It's actually the full spiral from an .080 left hand drill.... I had a stuck 3mm screw that I drilled the head off of... I couldn't find my handy dandy left hand drill package that had a bigger dia. assortment of drills... I figured I'd try with the only one I could find... an .080, as I figured it couldn't be in there tight I literally put the drill on it and gave it some juice & a "tad" of pressure... while holding it in my hand... 🤬🤬🤬 it snapped immediately!!! I originally thought just the broken part still in the drill stabbed me, but 3hrs later it was still leaking.... and started swelling.
And trust me, I looked all over tge floor looking for that broken spiral piece!!! Just hoping its not lodged into the joint....only an xray will tell!!! I'll keep yall posted... 😤😤😤Mike View attachment 342357
Just being stupid and impatient.....
Sir, you need to wear those medieval gauntlets when you work with power tools..
I broke an .035 carbide drill in my middle finger years ago... right on the top knuckle, in between the joint. .. urgent care got the big part out but unable to get the shattered bits out that were stuck in between the joint....carbide shatters!!! Even on impact with bone!!! That one needed surgery to get all the shrapnel out.... thus is atleast hss.. Mike
Ouch bro!
I've definitely drilled my hand in the same exact spor more then a couole times. That's when a drill breaks and you ram the darn thing into your hand... shouldn't happen because you shouldn't be pushing with that amount of force but hey, impatient happens..
I've never had a piece break off and be stuck in there though! Thats pretty epic man!
That's Mike in the dozer.... :unsure:
Make sure you get a pretty nurse..
That'll distract you as she yanks the broken bit out your hand.. 😉
No need to pay extra for the local anaesthesia.
Allset!!! Well, there is a tiny piece about 1.5mm in there... I'll tryi to get the xray up on my pc. He referred me to a specialist just to see if it needs to come out, or stay in... Mike
Mike if the nurse you get happens to not look appealing,you can allways look at that☝️ nurse 😁
That's good that you know what it is but the fact you can't remove it today kinda sucks .does it hurt if you press on it?
Ohh yea it's tender as sheet!!!
Hopefully none of your nerves are affected..had a friend that accidentally shot his finger with a bb pellet and they said it would cause nerve damage if they removed it .so he decided to leave it .when do you plan to go to the specialist? Hopefully tomorrow or soon
Have you poured water on the magnet?🤣
I’ve recently heard someone say that if you pour water on top of a magnet it loses it magnetism.🤣 I don’t want to derail this thread into politics so I won’t say his name.😉
Google is your friend “magnets won’t work under water”.
Happy Big Brother GIF by MOODMAN
