Limitless Limitless slow build thread.
Jason F
  1. Limitless
I am going to document my build, all parts I buy, and use.
Limitless roller
Castle Creations XLX2 ESC
Castle Creations 2028 1100kv motor
PPS motor mount diff combo
Saga Customs 8mm pinion/spur gears
Scorched RC Pinocchio spool shaft
Scorched RC diff lockers (front/rear)
Scorched RC carbon fiber Batwing
Scorched RC carbon fiber towers (front/rear)
Scorched RC carbon fiber Toyota GT 1 splitter
Scorched RC carbon fiber tower brace
Scorched RC carbon fiber Ackerman brace
Scorched RC carbon fiber top plate
Scorched RC carbon fiber side skirts GT
Scorched RC titanium pins
Scorched RC titanium splitter screws/nuts
Futaba 7PXR
Futaba GYC441 gyro
Futaba R2006GS receiver
Savöx servo
Still waiting for Scorched RC to get some parts in stock:
Scorched RC titanium front/rear axles
Scorched RC titanium ball mounts
Scorched RC ceramic bearings
I will update when I have parts to install.
Just ordered Caddx Vista Pro FPV camera setup
Jason F
  1. Limitless
So I know I’m jet lagged (got home after 1:00am) trying to figure out the best way to connect everything.
I have a Futaba 7PXR with R334SBS-E receiver
Futaba GYC441 gyro.
Question is: I would like to use the Telemetry feature, everything I have read confuses me more! Do I use S-BUS2 for the gyro, or Castle Telemetry Link?
Jason F
  1. Limitless
Tightened with red loctite, then added torque seal.
Installed some of the Scorched RC parts that showed up.
Garage is a mess, worked on both bikes today!
Sloclone100
Simpsonville, South Carolina
  1. Limitless
Limitless roller
Futaba 7PXR
Futaba GYC441 gyro
Savöx servo
View attachment 138303 Please help me with something. It doesn't look like 'sticking to a tight budget is your problem. So, let's say I have a friend???? Who has the car/xlx2/motor? I, (I mean he) have replaced the front and rear shafts and upper and lower braces. Now, the spaceship you intend on building would require a budget just about as large as NASA's. I have been R/C'ing for a very long time. Long enough to know that the companies that last, not only must build quality products, but they must make money. So my main question is: What do you consider the most other 'must upgrade parts on your list? (I plan an upgrade on the center diff).
Jason F
  1. Limitless
First off! (Don’t take this the wrong way) I work my ass off, and have worked for the same company for over 20 years. Before COVID-19 my Wife had a great job also! (Not anymore)
I think the most important parts for reliability on a speed run car is Scorched RC Pinocchio spool, front/rear axles, and diff locks front/rear.
Sloclone100
  1. Limitless
Thank you and I am sorry if I came off the wrong way. But when I read the list you compiled and knew I had most of the core stuff but would have to limit the 'important' stuff somehow. I would definitely do the upgrades, if for nothing else, just the fun. But I have just retired and, although I am setup ok, I can't spend like I used to back in the Xray years.
No disparagement intended. I am here, because just like the rest of us, I want to share and learn.
Drive straight. -Dave
Jason F
  1. Limitless
I'm loving your chopper, wow
Thank you!
I take no offense, I just wanted you to know I have earned everything I have.
Jason F
  1. Limitless
Well my airbrush blew up on me again!
Paint is pearl white outside, aluminum surrounding the pearl blue center. I’m not happy with it, next one I will use my new airbrush.
Jason F
  1. Limitless
I switched to one of my automotive paint guns, but it was already ruined. The airbrush is over 25 years old, so I can’t be that upset.
Jason F
  1. Limitless
I wanted high visibility on the asphalt road. Like my Wife said it’s not going to look good for long so don’t worry about it!
Next body I think I will do Lumilor paint.
Maine (downeast)
  1. Kraton 4s
