Looking good there. She looks so purdy and clean.
Answer to question in post 14. Forgive me if someone already answered...Set screw without threads. They did remember to put locktite on it thought
Nice dude. I run my Talion with a 15t and couldn't be happier.
Stock is 13T on that right? So you went up 2 teeth also? Any heat issues, are you running a motor fan?
I always do tight figure eights with brand new rebuilt diffs for at least 5-10 mins or longer. A proper break-in leads to more durable diffs. Been doing this forever. Ball type diffs can break-in fine done on the bench. Gear type diffs need a load to break-in, hence driving figure eights is best. IMO.Yea I had a feeling it just needed to be broken in. I never checked the diffs on my Notorious prior to driving it so I didnt have that as a comparison. Im sure it will be perfect after a couple runs. I also noticed that it got worse depending on how tight the 4 main screws are that hold the upper half on. So that must be putting extra pressure on the shim which also causes the mesh to be tighter.
Their called Dusty motors shock covers. Ebay item 392345564173Where did you get the shock covers? I can’t seem to find any
So the Xmaxx sized ones will fit the kraton 6s?Their called Dusty motors shock covers. Ebay item 392345564173
