- North Liberty, IA
- Infraction
- Kraton 6s
- Typhon 3s
- Typhon 6s
Ok y'all, I really don't like the idea of having a shelf queen (car or just a body), let alone 2 XO-1 bodies that I have never really used. I bought an Infraction roller from @Cereal_killer a while back for parts, but I don't need a 3rd speed runner or another parking lot basher. So I decided to try to build an off-road car out of the blank Infraction chassis w/ spare parts i have lying around. Stripped it down & started building back up by adding 3 new diffs, pps motor mount. Kraton towers were too tall to fit the body so I used the typhon tlr ones I had. Had to cut the ears off the rear to fit. Have lots of mojave arms/shafts but they ended up not being wide enough to clear the body. Had to order Kraton arms & axles from Jenny's. Those were just a little too narrow as well so I added some 17mm hex extenders. The only spare shocks I have on hand are mojave & they're a little soft (have some Kratons on the way)
The big ticket items I needed to buy were the motor & esc. I've got the hobbywing max6 4985 1650kv combo in all of my off-road bashers already & since I was going off the beaten path on everything else I decided to go a little crazy (ok, maybe a LOT!!) So I bought a max5 5687 1100kv combo, not like I'm the 1st guy to overpower an rc!! The motor is a REALLY tight fit but it's in there & I drilled new holes in the chassis & mounted the esc on some little spacers that came w/ some fans.
I got everything wrapped up tonight after finally getting the rx to bind to my nb4. Took it out for a quick shake down, but it was too dark to really get after it- but I can definitely say it's gonna be crazy!!! Right now I'm geared 30t/46p.
Hardly anything on this build was just bolt on, took lots of installing, grinding, taking off & grinding some more to get stuff to work. Not sure how many times I've taken it apart already & to be honest I might hate it & end up taking it all back apart & just building a regular (overpowered) kraton anyway!!
