Kla912000
Looks good!Hi no didn't realise that wanted to make my Typhon a little wider as made it a vw baja bug
Sorted it now had to use longer link
Cjees
Cjees
That looks awesome, esp the roof rack! Anything special you had to do to get the body fit?Hi no didn't realise that wanted to make my Typhon a little wider as made it a vw baja bug
Cjees
It used to happen to me often with Granite RPM arms. If the pin stretches the pin hole, it can re-occur easily. So far, since switching to Typhon RPM arms it hasn't happened again.anyone ever pull the pin out of their rear arm without breaking the arm? I had this happen last weekend.. i thought i broke a arm cause when i walked up on it I seen the pin was still in the knuckle. took 2 min to fix and it hasnt came back apart yet...
Im pretty rough on it! im covering about 60 feet between the ramp and landing on a full send run... so far the durability has impressed me
Needs mudflapsHi no didn't realise that wanted to make my Typhon a little wider as made it a vw baja bug
Cjees
