Thanks, right side turnbuckle needs to be adjusted, you have too much tow out. ( the upper lower one ? you mean to tighten down more ?)Your right side turnbuckle needs to be adjusted, you have too much tow out.
As far as it not moving when its off (I'm assuming your trying to say) couple things. The truck has tons of steering slop, I bet if you turn both tires at the same time it will move the servo when its off. Plus, high torque servos are supposed to be hard to move when they are off.. PLUS, looks like you were flexing the servo saver instead of moving the servo. Its supposed to work like that. You can tighten the saver down, that would help turning it when its off but honestly, who cares if it turns when its off?
