Mojave Super basic Mojave EXB build
  1. BigRock 4x4
  3. Senton 3s
Mojave exb. Max 6 combo. DIY fan mount. M2c lock hexes and droop screws. Body funs.
I like the waterfall double fan mount design. Seems effective without a HS for sure.
Keep us updated.:)
How about this.
To clean it I sprayed it off with a hose and that’s it
That is what i do with my granite. Dish soap with a mix of oil, and then I hose it off. Since it is a 4s Granite I don't care. Now, if it is my Senton/Outcast it is getting a nice warm simple green bath with a hit of air at the end.
So I am running max effect lsd up front with 50k, max effect lsd center with 300k and open rear with 30k. Anyone see any issue with this setup on this platform? Was basically just mirroring what works in my outcast other than the open rear which i have as minimum lsd in the oucast. Only one run through the truck at this point as i am still waiting for my scorched fenders to show up today or tomorrow. Thanks for any input from others that run the mojave exb
Let us know if you like that setup. Max lsd seems to ‘increase’ the oil thickness, so I wonder if you like that 50k with max lsd in front diff.
Im curious as well. Not a lot of places to run on dirt around here so it is usually just grass. It did well around the house last week for the maiden voyage. My outcast handles just like I like it with this setup. I am used to 2wd RC for most of my driving over the last 30 years. Stadium trucks were my thing. Still learning 4wd
Scorched liners on. Good overall but large access front and rear center. I may try to fit spare kraton guards up front. Not sure if these areas will pose a problem or not.
